THERMOSTAT OR NO THERMOSTAT?
jadamoon386 |
03-30-2026 @ 6:30 PM
I live in Florida and in addition to plugging the cabin heater core I was thinking about not installing a thermostat when I put the engine back into the car after the new clutch installation, comments?
ford38v8 |
03-30-2026 @ 7:02 PM
If your goal is to help keep the cabin cooler, the thermostat removal will have no effect whatsoever. A thermostat helps in bringing the engine quickly to operating temperature, which in turn, prolongs the life of the engine. Removing a functioning thermostat will not benefit any car, and prove to be a major r disadvantage in colder climates.
MG |
03-30-2026 @ 11:41 PM
Install a 180° thermostat to make your engine happy...Or, at least a 160° stat...
carcrazy |
03-31-2026 @ 12:05 AM
If you install a 160 degree thermostat, you will have a little more of a cushion when the ambient air temperature is warm and you are going uphill and working the engine hard.
JayChicago |
03-31-2026 @ 9:19 AM
I don't think you need to worry about going uphill in flat Florida. Your worry is long duration driving in very hot weather. Once the engine starts to get a little hot, every thermostat will be wide open, providing full flow of whatever the system is able to push through. Probably little or no difference than running with no thermostat. You could experiment, see if there is any difference with no stat on hot days. To burn off contaminants, you don't want the engine running cool. You want it to come up to temp quickly, and you don't want it running below operating temp on cool days/evenings. A 180 stat is best for that. The limitation of the cooling system on hot days is usually the heat-exchanger, how much heat is the radiator able to remove. Which thermostat, or no thermostat, won't help the radiator do its job.
52flatv8 |
04-01-2026 @ 5:08 AM
I too would use a 180 stat providing your radiator and water pumps are in good working order.
FordFreak |
04-01-2026 @ 6:23 AM
I always ran 180's in my '37. Never ran hot.
