EFV-8 Club Forum / Light Commercial Truck Discussion / 4 Speed Transmission Identification
Posted By Discussion Topic: 4 Speed Transmission Identification
FwJ1941
07-16-2025 @ 4:53 PM
Can any of you please help me with identification of a 4 Speed transmission that I removed from my 1941 Ford PU. When I purchased the pickup, it had a 51 Mercury
Flathead V8 engine installed in it. I suspect that the transmission is also a 51 Model. I cleaned some buildup on the right side of the case and it appears to be marked as follows: 51-7006.. Just below that is DG & M . And finally under the above is the marking, N 1. The raised lettering and numbers, especially the smaller
Markings are a little hard to positively make out.
Please note attached picture.
I’d appreciate any info you can provide. If you hav3 a sense for the value, I’d appreciate your input on that as well
Thank You!!!
Frank W Jones
07-16-2025 @ 7:48 PM
You might want to contact Mac Van Pelt for information on identifying your Ford 4-Speed manual transmission.
http://www.vanpeltsales.com/
FwJ1941
07-17-2025 @ 7:27 PM
Thank you for responding! And your suggestion to contact Mac Van Pelt. They will have the answers for sure!!
Frank
Frank W Jones
