EFV-8 Club Forum / General Ford Discussion / 1939 9" clutch disc replacement
Posted By Discussion Topic: 1939 9" clutch disc replacement
MICHV8
04-17-2025 @ 6:30 AM
Just want to verify that I should shim the 3 arms in their current position before removing the 6 pressure plate bolts?
Thanks
pauls39coupe
04-17-2025 @ 6:23 PM
Yes, use a small nut to act as a shim on each of the fingers. I keep them strung together with wire so they don't drop into the pressure plate when you re-install it.
Paul
MICHV8
04-18-2025 @ 5:47 AM
thanks!
