EFV-8 Club Forum / General Ford Discussion / fuel pump gasket 37-41 fuel bowl
Posted By Discussion Topic: fuel pump gasket 37-41 fuel bowl
41fatty
10-07-2025 @ 5:22 PM
I thought it would be easy enough to find a 2 1/4 in. o -ring to fit in my fuel bowl but it is not for me. Where to find proper gasket/ o- ring to fit in steel fuel bowl? they are difficult to cut out of gasket material being so thin and all. I thought an o- ring would seal best around the internal screen. Any advice?
41fatty
10-07-2025 @ 6:36 PM
In regards to fuel pump
MG
10-07-2025 @ 6:50 PM
This is what you need > https://thirdgenauto.com/product/new-1929-57-ford-fuel-sediment-bowl-rubberized-cork-gasket/
10-07-2025 @ 10:26 PM
For the steel bowl fuel pump W/O a glass bowl, you need Fuel Pump Top Cover Gasket #68-9364.
C&G has them in stock.
https://cgfordparts.com/catalogsearch/result/?q=9364&finder%5B1%5D=4766&finder%5B2%5D=787611&finder%5B3%5D=788104&find
41fatty
10-08-2025 @ 6:43 AM
thank you,the cork appears to overlap the screen inside.
41fatty
10-14-2025 @ 11:50 AM
apply this dry or with spray gasket?
10-14-2025 @ 3:18 PM
Apply a thin coating of Permatex #2 to the top surface only of the gasket to hold it in place when you tighten the fuel pump cover to the fuel pump. Make sure the bolt holding the cover to the pump is tight enough to prevent leaking but not so tight as to bend or otherwise harm anything.
41fatty
10-17-2025 @ 12:47 PM
the damage may already be done, and not a new brass screen to be found. At least not the original delicate brass framed ones. Any leads?
