EFV-8 Club Forum / General Ford Discussion / !941 Ford radio power lead
Posted By Discussion Topic: !941 Ford radio power lead
sq1954
09-26-2025 @ 5:30 PM
I am looking for the lengths of the power/ground leads of the 1941 Ford/Mercury radio. Philco radio.
sq1954
09-29-2025 @ 9:12 AM
Where does the wrapped ground lead exit the power lead, how long is it after it exits, and where does it connect to?
RAK402A
09-29-2025 @ 1:31 PM
I have a 1941 Ford radio around here somewhere (but am not sure where it is to examine).
I can measure the lead on the 1940 radio, but I am not sure it is the same. There should be a fuse in the power lead.
The 1940 (and I think the 1941 radios) ground where to the top center o f the dashboard with a special nut (which supports the weight of the radio). The antenna connects to the center of this nut, which is insulated from the dash/ground.
Dennis Carpenter makes a repro of this nut:
https://www.dennis-carpenter.com/cars/exterior/antenna-amp-radio/01a-18808-nut-to-hold-radio-to-top
I don't recall seeing a separate ground lead on the 1941 radio-I don't believe it had one (although one may have been added in the intervening 84 years to your radio). All of the images I can find on the internet show only the power lead.
There also should be two "J" shaped hooks with wing-nuts to restrain the front of the radio to the lip under the front of the dashboard.
This message was edited by RAK402A on 9-29-25 @ 1:32 PM
sq1954
10-02-2025 @ 7:24 AM
The 41 power lead has a woven ground lead wrapped around it that is soldered to the inside of the case.
RAK402A
10-02-2025 @ 9:06 AM
I stand corrected sir.
sq1954
12-09-2025 @ 7:41 AM
Someone suggested that the ground wire may just be wrapped around the power wire to reduce static on the radio.
