Topic: carb spring
tpls46ford    -- 09-12-2025 @ 8:28 AM
  Misplaced the the spring from the accelerator linkage to the carburetor. Having a hard time finding another one. Any suggestions?
thanks
tom
same    -- 09-12-2025 @ 10:08 AM
  you may be able to find supposedly oe design from c&g ford parts,joes ford parts in uxberg mass. couple yrs ago i got one and tried to install. it seemed to made ass backwards.i gave up and got a small package of throttle return springs from i believe it was autozone or oreillys. hook one end over or under throttle arm on carb and other end which should line up to hook over generator band small bolt. worked for me so far 3yrs. Tom. the coil section is probly 3-4 in. and each end from coil about 3-4in..
This message was edited by same on 9-12-25 @ 10:12 AM
TomO    -- 09-12-2025 @ 10:29 AM
  I don't remember any spring going from the accelerator pedal linkage to the carburetor on a 1946 Ford. The spring on the cross shaft (P/N 99A-9725 ) should supply plenty of tension to close the throttle. The reproduction spring is available and works.
same    -- 09-12-2025 @ 7:50 PM
  Oh,yep i wondered what year ford was in question me bad is hiding in plain sight in moniker. tom o. is correct. Tom. aka farmertom on ford barn.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17755
