Topic: Rebuild original 85hp 40 ford motor
sv221fh?    -- 01-26-2025 @ 10:43 AM
  Please give experiences and recommendations
marvin miller
CharlieStephens    -- 01-26-2025 @ 11:28 AM
  If you put your general location in your profile someone might recommend a rebuilder near you.
Charlie Stephens
sv221fh?    -- 01-26-2025 @ 1:53 PM
  Morgantown Wv
marvin miller
fordv8j    -- 01-26-2025 @ 4:03 PM
  Marvin did you by chance attend Normantown High school, in Normantown WVa--James Richard Parsons, my brother was Ronald
carcrazy    -- 01-26-2025 @ 4:23 PM
  I don't know of any rebuilders in your area but am willing to share some of my experiences with rebuilding a 1940 Ford Flathead V-8 engine with you.
1. Have the engine block and cylinder heads thoroughly cleaned and degreased.
2. Have the block and heads Magnaflux checked for cracks before beginning your rebuild.
3. Use the standard 1940 Ford oil pump on the engine - do not use the later higher volume oil pump unless you are willing to have the
crankshaft machined to allow the later rope seals to be used at the rear of the crankshaft.
4. You can use a partial flow oil filter if you want to.
5. You must modify the crankshaft and use rear rope seals if you use either a full flow oil filter or the later higher volume oil pump.
6. Once your engine is rebuilt, use a straight SAE 30 weight detergent oil with a break-in additive containing the required amounts of
ZDDP to minimize wear, oil leaking and oil burning.
carcrazy    -- 01-26-2025 @ 11:19 PM
  The Hemmings Collector-Car Almanac listed this outfit under Engine Rebuilding. This place in Louisville, KY may not be too far away from you.
https://www.milesmachineshop.com/machine-shop
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17415
