Topic: Batteries
jimlamarca    -- 11-09-2019 @ 4:50 PM
  Looking for members recommendations on the best 6-volt batteries for a flathead v-8 and where to buy them. 6-volts are not prominently featured on most automotive battery sites. Especially concerned about getting a 6-volt with maximum cranking amps for starting.
trjford8    -- 11-09-2019 @ 4:57 PM
  If it were me I would look at the 6 volt Optima. You can hide it in an original battery case.
jimlamarca    -- 11-09-2019 @ 6:41 PM
  Thanks, but would it fit under the front driver's side floorboard? I have heard the Optima's are too large and have to be jury-rigged to fit, or to modify the battery holder. I think one suggestion was to lay the battery on its side because it's too high to fit in the space. Any comments on that?
cliftford    -- 11-09-2019 @ 6:47 PM
  An optima battery will function in any position, even upside down,I'm told.
MG    -- 11-09-2019 @ 8:33 PM
  A Group 2LF Battery will fit under the floor.
See this battery > https://www.batterycentralmall.com/Batteries/TurboStart/Script/S2LF_L.html
This message was edited by MG on 11-9-19 @ 8:35 PM
42wagon    -- 11-10-2019 @ 4:09 AM
  A Group 1 6 volt battery will fit in the under floor battery tray in a Model A and the battery tray of a 42 although it seems to be slightly smaller than the original battery. Check but I would think it would also fit the battery compartment on your V8. As for cranking capacity a Group 1 works just fine in my 42. Group 1s are made by Interstate and are available at NAPA and most other battery stores.
sarahcecelia    -- 11-10-2019 @ 2:27 PM
  I got a Deka for my 1940 ford, $89 w/ 3 year warranty , good cold cranking amps, and needless to say I'm very happy with it and the price!
Regards, Steve Lee
TomO    -- 11-11-2019 @ 8:12 AM
  The Optima is 1.5" taller than a group 2L battery.
Here is a link to battery size by group number
https://www.batteryequivalents.com/bci-battery-group-size-chart.html
kubes40    -- 11-11-2019 @ 8:35 AM
  The Optima can easily fit beneath the floor board. It needs to be tipped at an angle. If authenticity is not paramount to you (it doesn't appear to be) then I'd go with the Optima. They last for years and will deliver the most CCA's.
jimlamarca    -- 11-11-2019 @ 8:28 PM
  Thanks, Mike
jimlamarca    -- 11-11-2019 @ 8:30 PM
  Thank you, Tom
jimlamarca    -- 11-11-2019 @ 8:31 PM
  Thank you.
fatso2114    -- 12-01-2019 @ 9:23 AM
  Try a group 4 battery it has 1100 cranking amp cold been using them for years will turn over like 12 volt ,it is a bit larger and you will need to modify your tray and hold down,can be purchased at Napa,John
37RAGTOPMAN    -- 12-01-2019 @ 3:35 PM
  batteries
TRACTOR SUPPLY has 6 volt batteries ,
might want to check them out, AROUND $95.00 plus trade in
my 2 cents 37Ragtopman
sarahcecelia    -- 12-01-2019 @ 4:38 PM
  "Deka" is what I put in my '40. $89, 3 year warranty and real good cranking amps!!
Regards, Steve Lee
  Optima is very expensive!!
Regards, Steve Lee
lightflyer1    -- 12-16-2019 @ 11:02 AM
  I bought two Optimas way back when they were on sale. When placed and wrapped together they fit just fine. I had a wiring harness made up by a boat wiring harness maker that connect s them up to make a super 6 volt battery. I also added a charging port to it so I can just pull in and plug them into my battery tender. Priceless!
This message was edited by lightflyer1 on 12-16-19 @ 11:02 AM
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13376
