| youngster | -- 02-23-2019 @ 8:47 AM |
Can anyone help with the wiring diagram for fog lights on a 1935 Ford coupe? Seem to be original lights, with one wire that needs to be connected. Just don't know where to connect it. Any help is greatly appreciated. Thanks, Bill
| TomO | -- 02-23-2019 @ 8:58 AM |
Bill, my guess is that you need to connect that one wire to a switch that is fed by 6 volts from the battery side of the fuse panel. The wire from the fuse panel should have an inline fuse holder with a fuse. You can find the battery side of the fuse panel by removing the fuse and using a meter or test light to find 6 volts. Tom
| 39 Ken | -- 02-24-2019 @ 6:57 AM |
The original switch on my '39 has a built in fuse. If the '35 is the same, wire it directly from the battery side of the fuse panel as TomO has suggested. Ken
| 40 Coupe | -- 02-24-2019 @ 10:36 AM |
Road lights were not offered by Ford as an accessory in 35 they firs appeared in 36. The early road light switches do not have a fuse. A couple of years later the fuse appeared on the ON/Off switch.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=12700 |
