| sq1954 | -- 09-01-2025 @ 4:06 PM |
I have a 1941 Philco radio. I have the power lead from the fuse holder to the circuit breaker. I know at the radio end there are the hot wire and a ground wire. The hot wire is covered with a bearded ground wire that exits the radio and clamped down to the case. from there the hot wire with the bearded ground wire are covered by a cloth bearded covering. What I need to know is the length of the wire from the clamp to the fuse holder. I also need to know where the ground wire exits/ how long is it after it exits/ and where does the ground wire connect to? Any help please. Thanks.
| sq1954 | -- 09-29-2025 @ 9:09 AM |
On the 1941 radio power lead the wrapped ground lead where does it exit the power lead, from there how long is it, and where does it connect to?
| TomO | -- 10-04-2025 @ 6:36 PM |
Posted in error This message was edited by TomO on 10-4-25 @ 6:40 PM
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=17738 |
