| dknechtly | -- 03-26-2021 @ 12:11 PM |
Hi. Helping my friend with his 1948. Is there a trick (order) to install the plug wires with domed distributor? We can't get the dome back on. I'm guessing the wires are crossed. That's a lot of wires to fit under there. Thanks
| kubes40 | -- 03-26-2021 @ 12:50 PM |
No tricks really. It is not a fun task. Patience, patience. Mike "Kube" Kubarth
| dknechtly | -- 03-30-2021 @ 4:42 AM |
I greatly appreciate the reply. We got it back together but had a miss. Have to pop the cap back off. Another question... I see conflicting info on the terminals (at the cap). Should they be the 90 degree bent ones or straight?
| kubes40 | -- 03-30-2021 @ 5:56 AM |
Factory were straight. Mike "Kube" Kubarth
| whizzerbug | -- 03-30-2021 @ 7:52 AM |
i did away with that cap setup and went with a crab cap best move i ever made
| dknechtly | -- 04-02-2021 @ 9:49 AM |
Thanks for the replies guys. We've talked about the going to the crab style but I've seen conflicting things. I can see the crab might be an issue out in the weather, rain, snow, slush... but most likely the only water this one will see is when it's getting washed.
| TomO | -- 04-03-2021 @ 11:16 AM |
My car saw much more than a little rain at the 2019 National Meet at Auburn. You never know when you are going to get caught in a storm, unless you live in the desert. Tom
| dknechtly | -- 04-05-2021 @ 7:38 PM |
Very good point.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=14&Topic=14712 |
