Topic: 47 Conventional Running boards
rawlir    -- 08-20-2025 @ 6:41 PM
  Hi, all!
Anyone know about the Carriage type bolts anchoring the running boards to the running board brackets on either 1/2 ton or Tonner pickups? Do you know if they would be the same between 1/2 ton or Tonner?
I think heads are 3/4" wide (approx) by 1 5/8" long, 6 per side. Square shoulders under the heads.
I need 12, anyone know where i might find some?
Thanks for help or referrals!
Rick
carcrazy    -- 08-20-2025 @ 11:32 PM
  C&G may have the carriage bolts you are looking for.
https://cgfordparts.com/universal-carraige-bolt-5-16-x-1-1-2-long-9491.html
rawlir    -- 08-22-2025 @ 7:03 PM
  No to C&G......
nelsb01    -- 08-22-2025 @ 8:27 PM
  Did you try Third Gen?
Check out page 33 of the hardware catalogue.
https://thirdgenauto.com/wp-content/uploads/2021/08/MARCHv8CATFOR-WEB-USE-2018.pdf
rawlir    -- 08-23-2025 @ 7:02 AM
  I have a call into 3rd Gen, cannot see on page 33 which is a fit for a 47 Tonner Express pickup....
Thank you for pointing him out!!
nelsb01    -- 08-23-2025 @ 12:28 PM
  Just guessing here..............but you would think that the passenger vehicle and commercial bolts would be similar, but then, Ford did have different parts for different vehicles.
rawlir    -- 08-23-2025 @ 4:44 PM
  These are weird bolts, much bigger but flatter head than a carriage bolt, bigger square shoulder under head, yet the shaft diameter needs to be small to fit thru holes in board brackets....
carcrazy    -- 08-23-2025 @ 9:33 PM
  Perhaps some of the running board bolts offered by Bob Drake will work for you.
https://bobdrake.com/search?type=product&q=RUNNING+BOARD+BOLTS
rawlir    -- 08-24-2025 @ 7:55 AM
  Drake photos don't look right but i will be checking in with them....I suspect i might have to make them.....Thanks!
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=21&Topic=17725
