Topic: Early 1932 diff pinion upgrade.
AussieV8    -- 05-31-2026 @ 5:58 AM
  I have an early 1932 rear axle assembly which is 4:11 ratio and want to fit a higher speed gearset 3:78 ratio. The driveshaft is welded to the pinion shaft so I assume the weld will need to be machined off and then the new pinion welded on. I have not seen any procedure for this. Can anyone tell me where to look or supply a procedure.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=19&Topic=18118
