materguru | -- 10-01-2023 @ 12:51 PM |
i could use some advise. i am getting power to the wires going to each headlight from the light/horn rod bell. i lose power when i try to plug the 3 prong end that i have had made for sealed beams. i have power to the turn signals that i had rearranged when ordered wiring to make the top of bucket bulb as a turn signal. i lose the power from the plug bullets to the rubber plug in of the bulb wiring. i hope its not too confusing but please if not clear please ask any additional question to further diagnose. thanks to all in advance.
TomO | -- 10-09-2023 @ 4:24 PM |
I am not sure what you have wired up. I also don't know how and where you are measuring power going to the wires the feed the headlights. As a suggestion you could run a 14gauge jumper from a battery source to the plug for one of the sealed beams and see if it lights up. If it doesn't run another jumper from a good grounding source like the battery or motor. I use a paper clip to back probe the plug when I check voltage. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=19&Topic=16693 |
