MICHV8 | -- 06-04-2022 @ 8:32 AM |
I see many good suppliers (C&G for instance) use part # B-7050920 and yet MACS (sorry not fond of) uses 40-705018-A (40 to me indicates 1934) Is one of these correct? Or can someone recommend the correct source? Also, is there a trick to trimming the excess material under the trim after install without scoring the top paint? Thanks!
1931 Flamingo | -- 06-05-2022 @ 5:43 AM |
Ask this question on the Ford Barn as David G there is an expert on 32 Fords. Paul in CT
3w2 | -- 06-05-2022 @ 4:38 PM |
I'm 3w2 here; see my response on his other posting of the same question in general Ford discussion. David This message was edited by 3w2 on 6-5-22 @ 4:43 PM
MICHV8 | -- 06-16-2022 @ 7:18 AM |
If the strip is straight, won't it wrinkle at the corners? Thanks!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=19&Topic=15714 |
