| Frosty | -- 02-15-2016 @ 8:06 PM |
Hi: Can anyone ID an H 33170 transmission? Will it mate up to a 1946 flathead engine? And will that combo fit into a 1938 Woody? Cheers, Al
| CharlieStephens | -- 02-15-2016 @ 8:36 PM |
How about a picture? Or a thousand words. The numbers don't mean anything to me but I am used to the earlier cars. Where are you seeing these numbers? Charlie Stephens This message was edited by CharlieStephens on 2-15-16 @ 10:10 PM
| 40cpe | -- 02-16-2016 @ 6:20 AM |
Isn't "H" a Lincoln designation? Is it an overdrive transmission? If it is, and your frame is original, it won't fit without lots of mods.
| Colin | -- 02-16-2016 @ 10:00 AM |
The number H33170 on a transmisson shows that it is a 1937 Lincoln-Zephyr. This is the 3 speed, no overdrive and floor shift. As far as I know it should mate to a 1946 engine and will fit a 1938 Ford. Ratios are the same as Ford. Hope this helps Colin
| Frosty | -- 02-17-2016 @ 4:34 PM |
Colin: Thank you very much for the info. I took pictures today for posting but I guess I don't need to do that now. Cheers, Al
| Pickup | -- 02-18-2016 @ 12:37 PM |
1936 & 37 Lincoln Zephyrs used the Ford transmission. The internals will be the same as Ford.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9390 |
