Topic: 41 ford convertible top motor
41 SUPER DLX    -- 10-20-2014 @ 7:11 AM
  thanks for any help up front. I went to put the top down on my 41 super deluxe convertible last weekend and the driver side was not moving. I was able to disconnect it and lower it manually. The passenger side motor works fine. It looks like the motor died from my trouble shooting. I was looking for a source for a replacement motor. The car has the screw type acuators no the hydraulic or vacuum. I have only had the car a few months so i am still learning about the different resources. I searched C&G, dennis carpenter, and Mac's online without much luck. I am in Connecticut if there is any local sources. thanks again
TomO    -- 10-20-2014 @ 7:28 AM
  I doubt that you will find a new motor for your top. I recommend that you find a local electric motor repair facility to repair your motor.
I did a Google search and found this outfit in Hartford:
http://remisi.com/
If you are a member of the V-8 Club, contact Ray Beebe in New York and ask his advice on a repair facility.
If you go this route, I would pull the other motor and have it checked out at the same time.
41 SUPER DLX    -- 10-20-2014 @ 9:22 AM
  Thanks for the help. I was thinking to rebuild or replace both motors to help combat the potential for different speed trying to twist the top.
supereal    -- 10-20-2014 @ 11:03 AM
  There is a fine article in the latest V8 TIMES outlining how a '41 was refitted with hydraulic cylinders to replace the jack screws. I use the same motor/pump from Hydro-E-Lectric. The only problem was the switch supplied wasn't heavy enough to carry load. so I built a relay power box. The jackscrews were a constant problem, and the hydraulic system was adopted in '42. The problem returned when the hardtop convertible arrived. It use a number of screws, and was a bear to get to work.
mace46    -- 10-20-2014 @ 3:53 PM
  I had both of my motors rebuilt by John Pinto in Philadelphia, PA. His phone # then was 215-739-1132.
jpinto@gtcinternet.com They have worked fine so far. Charles
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=7836
