Topic: 1934 FORD MODEL 46 PICKUP WITH 1946 FLATHEAD
DES    -- 07-17-2012 @ 4:33 PM
  I HAVE A FEW QUESTIONS ABOUT MY 1934 FORD PICKUP THAT HAS A 1946 FORD FLATHEAD
1. WHAT IS THE TEMP.RATING OF THE DRIVERS SIDE HEAD AND WHAT IS THE TEMP. OF THE PASSENGERS SIDE HEAD ?
2. WHERE CAN I FIND THE ORIGIONAL 6VOLT POS. GRD. WATER TEMP. GAUGES ?
3. WAT IS THE OIL PRESS.RATING FOR A 1946 FORD FLATHEAD ? WHERE CAN I FIND A 6VOLT POS. GRD. OIL PRESS. GAUGE ?
4. FORD FLATHEAD ENGINE OIL ?
MY FLATHEAD HAS BEEN RE- BUILT WITH ABOUT 50 MILES
ON THE ENGINE. I HAVE SAE-40 HEAVY DUTY MOTOR OIL.
CAN I CHANGE TO A 10/40 WT. OIL ? OR CAN I PUT IN
A SYNETHIC MOTOR OIL LIKE ROYAL PURPLE SYNETHIC
MOTOR OIL ?
5. I AM ALSO LOOKING FOR A 6VOLT POS. GRD.16" PULLER
FAN THAT MOUNTS ON THE INSIDE OF MY RADIATOR FOR
ADDITIONAL COOLING.
TomO    -- 07-19-2012 @ 4:31 PM
  Stock 1936 Fords use a cooling system that is not pressurized. Coolant temperature should be between 160-180 at normal operating speeds.
The temperature gauge on a 34 is not electric. You can advertise for one in the classified section of this website.
One of the quality vendors for parts is C&G Ford parts.
http://www.cgfordparts.com/
alanwoodieman    -- 07-19-2012 @ 6:00 PM
  try to stay away from synthetic oils-tends to leak where there were not any leaks before- a lot of guys and I use 20w50 oil, stays in the engine, I use Kendall 20w50 with ZDDP, buy it at autozone, advance, etc
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4949
