| grump40 | -- 09-13-2011 @ 7:34 PM |
Old topic revisited...Will have to remove the head and leaking stud in oder to fix. Can someone please tell me the stud lengths for #9 and #12 in the torque sequence ? Thx grump40.
| supereal | -- 09-13-2011 @ 7:44 PM |
As long as you have the head off, it is better to replace all the studs on that side. If two are seeping, it is a good bet more will follow. Use a good sealer, such as Permatex, on the block ends after you clean the holes in the block, and turn them down only until you feel them bottom out.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3747 |
