Topic: 37 Club Cabriolet door scuff plates
rlh37ford    -- 07-23-2011 @ 2:34 PM
  Are the scuff plates for the 37 Club Cabriolet different than for the 37 Rumble Cabriolet & Roadster? Can’t find my body parts list to identify the PN & body application. Help, please.
37RAGTOPMAN    -- 07-24-2011 @ 10:41 AM
  how long is you door opening ? or length of the old door scuff plates ?
lets us know,,,,,,,37RAGTOPMAN
37RAGTOPMAN    -- 07-24-2011 @ 11:13 AM
  according to my 37-38 FORD BODY PARTS LIST,
the part number for door scuff plates is
78-712150 RH
78-712151 LH
it does not list the cars seperate so I would assume they are the same. hope this helps 37RAGTOPMAN
rlh37ford    -- 07-25-2011 @ 11:45 AM
  37RAGTOPMAN: Thanks for info info you sent on PNs. Interesting; they are different than the C & G, Drake, Carpenter, & MAC catalogs. I find this interesting. Also, the catalogs list different PNs for various body styles. Anyhow, as soon as I find my originals in the barn, I'll post length. I can post door bottom length sooner. Then anyone with a rumble cabriolet or roadster could measure their door bottoms & provide that info. This could help others too. Stay tuned.
37RAGTOPMAN    -- 07-25-2011 @ 1:43 PM
  hi
I checked CARPENTER'S catalog and they are not in there,
just for Coupes,Sedans Conv Sedan and PHAETON
and a few other models.
they were made at one time, maybe will be making for both CABRIOLETS and ROADSTERS for 1937-1938 at some time in the future..
you can call Drake and see if they have any, I think they are the ones making them,
I have a 1937 78-760-A Hope this helps 37RAGTOPMAN
rlh37ford    -- 07-26-2011 @ 1:39 PM
  37RAGTOPMAN: You suggested I send measurements for comparison. My door length across outside bottom is 42”. Scuff plate overall length along top of rolled flange that sits on floor & extends inside hinge/lock pillars is 40 ½”. Scuff plate length of patterned vertical surface between pillars is 40 1/8”. How do these dimensions compare with your 78-760-A? Thanks, Dick.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3451
