| jwall | -- 07-20-2011 @ 2:39 PM |
Just a little background, I am redoing a 1936 Ford 5 window coupe. I put a 35 frame under it and it has a 37 engine. I am pretty sure it has a 36 radiator in it, so my questions are; is there much difference in a 36 and 37 radiator as far as capacity, and what should I use as antifreeze in this radiator. I also found the radiator cap I need from another posting.
| supereal | -- 07-20-2011 @ 8:38 PM |
We use Sierra antifreeze because it tends not to foam as much, particularly in non pressurized systems. Depending on where you live, the mixture is somewhat different than the common "Prestone" type. In our area, we use 60/40 mixture of Sierra and demineralized water, and pre mix it prior to installation. Just pour it in until the radiator is filled, then run the engine until it is warmed to be sure no air locks exist. For the job, buy two jugs of Sierra.
| jwall | -- 07-21-2011 @ 11:09 AM |
Thanks for the info. Will try to find som eof it here in Kansas.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3431 |
