Topic: 1948 Ford Clock
JerryW    -- 07-20-2011 @ 12:56 PM
  I believe I am missing the condensor for the clock in my newly purchased 1948 Ford convertible.What part can I substitute the part with, possibly an ignition condensor?
Any Ideas?
supereal    -- 07-20-2011 @ 1:04 PM
  If your clock is the type wound by an electromagnetic "kicker", you don't need a condenser. We have repaired a number of those over the years. If they don't wind automatically, the usual cause is dirty contact points, or a broken fine wire to the coil. As the clock runs down, the points close, then the coil pulls a lever that winds the clock spring. It happens about every five or six minutes when the clock is in good shape.
JerryW    -- 07-20-2011 @ 3:56 PM
  Thanks for the reply. The clock works fine after a little cleaning. Had viewed some clocks on E-bay and they appeared to have a condensor on them, although the wiring diagram doesn't show one. Just thought a condensor would extend the point life in the clock
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3429
