Topic: King Pins 48 ford sedan
jethro48    -- 07-19-2011 @ 3:43 PM
  I am getting ready to install new king pins on my 48 ford sedan. I have never installed king pins, but I do have a lot of mechanical experience, have done steering/suspension work, but it is all later model, ball joints etc... I cannot find any installation instructions and don't want to just "get a bigger hammer". What are the basic procedures for this job?
supereal    -- 07-19-2011 @ 4:40 PM
  Take the spindles, bushings, and the king pins to a good machine shop to have them fitted, then bolt it back together.
TomO    -- 07-20-2011 @ 8:07 AM
  To remove the king pins:
Remove the wheels and brake drums
remove the backing plates and suspend them to relieve stress on the brake hoses
Remove the nut holding the locking bolt
drive out the locking bolt
take a picture of the spindle and king pin so you can reassemble the parts in the correct order
drive out the king pin from the bottom
take the spindles and the kit to a machine shop to have the bushings pressed out, new pressed in and reamed to fit the new king pin.
reassemble.
If I forgot something, another poster will help out.
supereal    -- 07-20-2011 @ 10:12 AM
  It is likely that the king pins will resist efforts to drive them up and out. That's where the "bigger hammer" comes in. If you can, raise the front of the car high enough so you can get a good swing, and place a good punch (drift) under the end of the pin and swing the hammer upward. It is best to hold the punch with ViseGrips, unless you have better aim than I do. If you have an air tool, sometimes they will shake them. Badly worn or rusted pins tend to hang up in the axle end, taking a lot of "persuasion".
jethro48    -- 07-20-2011 @ 7:07 PM
  Thanks for the advise, the left side is out, I will tackle the right side tomorrow. The vise grip idea was helpful, I would not have been willing to use the bigger hammer with my hands in harms way. Thanks for all the help.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3422
