| ticker | -- 07-18-2011 @ 6:54 PM |
37 ignition lock question? does anyone have a mech.drawing of locking mechanism.The key cylinder is allready removed.Is the pin that moves the contact removeable? Thanks in advance for any info. Ken
| 40 Coupe | -- 07-19-2011 @ 4:34 AM |
The pin is removable but it is not easy, it is pressed in place and serrated. Some guys use a claw hammer to pull it out. I have not seen a ford diagram of the mechanism internals. It is best to work on the mechanism on the bench and not on the car. I believe Don Rogers has a written procedure for disassembly. See the V8 Times advisory panel list in the V8 Times.
| JM | -- 07-19-2011 @ 5:04 AM |
Don Rogers put together a nice set of instructions, with sketches of all the individual parts, for taking the column drop apart and putting it back together. You could send him a PM and ask him to send you a copy or you could PM me with your email address and I could send you a copy. Flathead fan also has written instructions for this but you would have to contact him for a copy of those. JM This message was edited by JM on 7-19-11 @ 12:29 PM
| ticker | -- 07-19-2011 @ 7:41 AM |
ksma1003@bellsouth.net Thanks for your help
| JM | -- 07-19-2011 @ 12:38 PM |
Information sent to your email address. JM
| 37pickupford | -- 07-20-2011 @ 5:25 PM |
I would love to see some good diagrams also. jsnyder223@comcast.net
| ticker | -- 07-21-2011 @ 8:03 PM |
Hey JM. Never did get your e mail must be lost in cyber space.I'd appreciate it if you tried again.
| JM | -- 07-22-2011 @ 4:06 AM |
ticker, I sent another message with attachments. 37pickupford, I sent you the info as well. JM
| rlh37ford | -- 07-23-2011 @ 7:27 AM |
Hi, JM: I hate to add to your tasks, but--would you please send the same info to me. Working on a 37 Club Cabriolet. Email: rlhate@ptd.net. I see you're not far away as I'm in PA. Sincere thanks, JM. ~Dick
| JM | -- 07-23-2011 @ 5:37 PM |
Dick, I will send info to you tomorrow when I can get back to my computer. Where are you located in PA? JM
| rlh37ford | -- 07-24-2011 @ 7:38 AM |
JM: I'm located about 12 mi. S.E. of Allentown, PA in lower area of Lehigh County. Thanks, Dick
| 37pickupford | -- 07-26-2011 @ 7:14 PM |
Diagrams received. Thank You.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3416 |
