Topic: Sleeves
RG/NJ    -- 07-16-2011 @ 2:01 PM
  Hi Guys; What supplier would you recomend for the hardened axle housing sleeves? Thanks
supereal    -- 07-16-2011 @ 2:29 PM
  We use C&G. Any sleeves should be tested for "Rockwell" hardness. A few years ago, there was a big problem with unhardened sleeves that lasted only a few miles. Given the extent of the job to remove and disassemble the axle, and the cost of machine work, being sure is vital. Most good machine shops can test the parts before installation. They should also check to be sure the housings are straight. The C&G part number is B-4012 (800/266-0470)
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3402
