| john38coupe | -- 07-06-2011 @ 7:59 PM |
Shopping for a fuel line in the restoration of my 38 coupe. The one I took off the car was one piece rigid steel and I'm aware I need copper plated steel tubing as original. I see there are many on the market....any recommendations of a good product? Classic Tube, located in Western NY., advertises in Hemmings, can create most anything but I assume I don't need that level of detail. Thanks
| supereal | -- 07-06-2011 @ 8:43 PM |
We buy ours from C&G, about twenty dollars. The come with fittings attached, and are the correct copper coated steel.
| 40 Coupe | -- 07-07-2011 @ 3:19 AM |
Dennis Carpenter also sells the coated steel line with fittings. Some of the aftermarket suppliers are supplying copper line so be careful.Napa also sells the 1/4" coated line in a box but they will not devide the length, they also have the fittings.
| TomO | -- 07-07-2011 @ 7:15 AM |
Roy Nacewicz and Narraganset Reproductions sell a fuel line that is an exact duplicate of the original. It has a heavier copper plating than the ones being sold by other vendors. Tom
| supereal | -- 07-07-2011 @ 12:26 PM |
Never use all copper tubing for a fuel line. It will fatigue and crack, causing a fire hazard.
| kubes40 | -- 07-07-2011 @ 1:30 PM |
I also prefer Nacewicz's lines. Once fitted, it's a good idea to solder the ferule to the line as Ford did back in the day.
| john38coupe | -- 07-14-2011 @ 6:47 PM |
Thanks - Purchased a Nacewicz brand while in Saratoga and it looks good
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3353 |
