| silverchief | -- 11-25-2026 @ 10:22 AM |
Had radiator in my 46 in the shop for routine cleaning and change coolant. Now my temp gauge comes to rest at the halfway point when the engine cools down instead of all the way back, so bringing the engine back up to operating temp shoves the needle past the hot mark. How can I correct this?? Thanks much
| 51woodie | -- 11-27-2026 @ 8:04 AM |
I don't think it is the rad work that is the issue, I suspect the cause may be electrical. Ford designed the oil pressure, temp and fuel gauges to be failsafe. If the connection between a sender and a gauge became "open", oil would go to zero, temp to hot, and fuel to empty. I suggest you check the connection and wiring between the right and left senders and at the wire going to the firewall. The temp gauge on my '46 Coupe became erratic, and I found the wire had broken away at one end of the crossover wire connector but was held in place by the cover. Nothing to see, but that was what I found when checking the connections. This message was edited by 51woodie on 11-27-26 @ 8:08 AM
| silverchief | -- 11-27-2026 @ 10:38 AM |
Thanks very much 51 Woodie. I will check it out.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18346 |
