| Davio | -- 11-23-2026 @ 8:54 PM |
I just acquired a 49 Ford Fordor custom. I need help converting it from a 6V to a 12V system. Can you recommend and kits and/or step by step directions on how to do this?
| carcrazy | -- 11-23-2026 @ 9:13 PM |
The best thing I can recommend is to purchase "The Official 12-Volt Conversion Guide" by Randy Rundle of Fifth Avenue Antique Auto Parts. His phone number is 785-632-3450. His little booklet covers all of the details and his outfit sells most of the parts you will need to do this conversion. Their website is www.fifthaveinternetgarage.com
| 1911tex | -- 11-24-2026 @ 7:49 AM |
Carcrazy: I am not about to convert my '35 to 12v; however, I have to commend you for answering this posters question to the point and completely!
| JayChicago | -- 11-24-2026 @ 11:10 AM |
Davio, welcome to the Forum. Hope you get much enjoyment out of your new '49. Here is my take on 12 volt conversion: Lots of old Fords have been converted to 12 volt. It was the thing to do when these cars were being hot rodded in the sixties. But now many would question, why do it? Just because you can? Now these cars are looked at as antiques. They should be preserved as such. The 6 volt system works just as well as 12 volt. However, 6 volt is less forgiving of poor electrical connections, so all of us have worked on cleaning connectors and grounds. But that is easy enough to do. The conversion is a bit of work, requires changing the battery, alternator, gauge adaptors, bulbs, etc. I would not go thru all that for no good reason. You do need 12 volt if you have something special like an electric cooling fan, but now we are into hot-rod territory again.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18342 |
