Topic: Engine Upgrade Etc.
HaroldL    -- 11-21-2026 @ 3:08 PM
  1.I plan to replace the two rubber radiator hoses that go from the center of the head to the radiator. I bought a kit from speedway, two rubber hoses and a chrome plated pipe that goes between the two short rubber hoses. I am not able to get the hose on the head outlet? Too small? Cooments?
2. I bought a set of Acorn nut covers from Speedway, I cannot get them over the nuts, even with the paint removed. I heard Bob Drake had some that could be opened up. Any comments?
3-The choke linkage is too long. Can someone explain the rubber coupling? I have not tried to take apart. I don't want to wreck it.
Thanks Harold
Harold Legreid
pauls39coupe    -- 11-21-2026 @ 5:15 PM
  I am guessing you have a pre 1949 engine with center outlets. Those chrome pipes are designed for use in 1949 and later engines which have smaller water outlets near the front of the engine.
The acorn nut may be made to fit engines with cylinder head bolts(49-53's). Call Speedway to check. They are usually quite helpful.
The rubber piece is a flex joint which should fit, if it is a stock engine
What year car do you have and what year engine is it?
HaroldL    -- 11-22-2026 @ 4:58 PM
  1947-59 AB
Harold Legreid
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18339
