| 1911tex | -- 11-18-2026 @ 3:02 PM |
Example: In 3rd gear 35 mph, let go of the accelerator and the car almost maintains its speed with an extremely slow deceleration for 50 yards. Brake, drop down to 2nd gear, same story..barely hear 2nd gear normal deceleration whine slowing down. No such thing as slowing in 3rd to 2nd gear preparing to slow down or 2nd in prep to a stop without excessive use of brakes. I let someone drive...comment: "Runs terrific, but why doesn't it slow down normally when foot is off the gas, it's like a race horse"? Maybe it's inherent in these early Ford V8's on modern smooth roads? Single Stromberg 97 carb. Stock transmission. Quick start, no slop in the accelerator pedal, at idle (500rpm) quick throttle advance and very fast deceleration. Gun engine at idle, let go of the pedal...very fast engine deceleration back to 500RPM, i.e. no carpet mat drag. At shut off, no run-on. No rich exhaust. Shifts normally, excellent clutch. 30# air in stock type tires. Thoughts, advice? Thank you. This message was edited by 1911tex on 11-19-26 @ 6:50 PM
| JayChicago | -- 11-19-2026 @ 9:03 AM |
Deleted. No longer relevant. This message was edited by JayChicago on 11-21-26 @ 7:10 AM
| 1911tex | -- 11-19-2026 @ 6:53 PM |
Jay you are correct, thank you...I made your recommended paragraph flip.
| carcrazy | -- 11-19-2026 @ 7:33 PM |
Your engine may have a lightened flywheel which has less tendency to reduce engine acceleration and engine braking.
| 1911tex | -- 11-20-2026 @ 5:18 AM |
Carcrazy that is very interesting....never considered or heard of a lightened flywheel! I guess there is no way to discover that by casual observation? Makes sense. Maybe that is why in neutral, with the slightest press on the accelerator, the engine revs zoom up? I did a A.I. search and there is a lot of flathead flywheel information and lightened flywheels for sale! Was that a common practice back in the day? This message was edited by 1911tex on 11-20-26 @ 7:13 AM
| 40 Coupe | -- 11-20-2026 @ 5:33 AM |
When driving and you coast to slow does the engine RPM slowly decrease? What happens to engine RPM if you you are coasting to slow and depress the clutch? Suggest disconnecting linkage at the Carb. and operating all the linkage by hand including the Carburetor. Then depress the gas pedal does it return by itself or stay depressed? The pedal should return with the Carb. linkage disconnected. There is a hole in the linkage across the firewall some light lube can be added there and the linkage return spring should work with ease.
| 1911tex | -- 11-20-2026 @ 7:07 AM |
40 Coupe: To answer question #1...my Coupe is stock (I thought..lightened flywheel?) and does not have an RPM instrument; however by ear and speed, I can say that the RPM decreases very, very slowly over 50 yards (almost like a cruise control), causing me to use mild tap braking to get to 2nd gear speed, then again RPM decreases very, very slow. I have had to program myself to give plenty of lead time when a stop is required. Question #2...never thought about that test (consiously pushing clutch to test engine speed then releasing)..I have only depressed the clutch to shift down when speed is slow enough using mild braking. Very good questions, will follow up on depressing clutch when coasting to test no load RPM. Theory says no load would slightly increase RPM? I will take your suggestions on lube and linkages next week on my next drive, and report the results back. Incredible forum!!!
| AzBob | -- 11-21-2026 @ 6:07 AM |
A lightened flywheel would allow faster acceleration and faster deceleration. There is less mass or stored energy in the flywheel. Engine braking would be more effective rather than less effective.
| 1911tex | -- 11-21-2026 @ 6:36 AM |
AzBob...I just read on A.I., your same statement which is the reverse of my problem. Going to do a re-evaluation after Thanksgiving and report back. I hope not to have a lightened flywheel...hope my tests suggested by 40 Coupe above will give a better review.
| 1911tex | -- 11-22-2026 @ 11:24 AM |
O/P here: Thanks to all who assisted me on this deceleration issue! I could not help myself, snuck out at beginning daylight this Sunday morning to test the results of all the suggestions; and a special thank you to 40 Coupe! I followed his suggestions (disconnecting the linkages at carb), now all cleaned and lubed. Yes now gas pedal pops back to idle with linkages disconnected as well as connected...all properly lubed and hand operated several times. Rubber grommets in the linkage holes in firewall removed, cleaned and lightly lubed with silicone for rubber and replaced. The large accelerator return spring cleaned with pressure from rattle can brake cleaner, then lubed...I never believed so much crud could fall out...I don't believe it has been cleaned and lubed for the past 91 years! All connections in the carb degreased, lightly lubed re-attached. Hit the starter, with light choke, no foot on the gas pedal....the flathead immediately started at what seemed a completely unexpected 2000 rpm (scaring the beegeebers out of me)!....had to kill the engine, open the hood and turn down the idle speed screw a full half turn, then hit the starter, she woke up immediately at what seemed 1000rpm...I turned down the idle speed screw to what sounded like a smooth 500-600rpm by ear and feel (I ordered an rpm laser gauge for accuracy from Amazon...should arrive Monday). I have no idea which of the cleaned, lubed connections/springs loosened which linkages that caused the initial unexpected very high rpm! I took the Coupe to a quiet street to test the results..the car ran incredibly smooth up to 35mph, let off the gas and for the first time, the coupe gradually slowed down normally to 20 mph with "no braking", shifted into 2nd, let go of the gas listened to the 2nd gear whine down to a full stop with "no braking". The old engine idled like it could respond to the old "balance a coin" brag! Drove around stop and go for another 20 minutes then back to the house. Look like I have the stock flywheel..whew! Opened the hood, took a laser temp gauge....178 degrees on the heads, 182 degrees at radiator intake and 166 degrees at radiator out into engine. OAT this morning was 59F degrees. Thank you good folks and thank this incredible forum!!!! Plenty happy!
| 1911tex | -- 11-22-2026 @ 3:04 PM |
O/P here again. Took the Coupe out this afternoon for a short run, just to satisfy myself that no pre-existing problem arose. Happy to report previous report above this morning was accurate. Still cannot figure out what caused the very high rpm startup. I could understand a very low RPM startup problem, but not the high RPM startup. Thanks again.
| Barney | -- 11-22-2026 @ 4:59 PM |
Hello 1911, Lightened flywheels were usually used in race cars that raced on oval tracks; faster acceleration on straight-a-ways and quicker braking when coming into a turn. Check to determine if your flywheel is cast iron or possibly aluminum; easy to check with a magnet. Barney
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18337 |
