| Barney | -- 11-16-2026 @ 5:05 PM |
Hello to All and an early Happy Thanksgiving, I'm sitting at a red light in moderate - heavy traffic all fat, dumb and happy in my '40 Ford flathead this afternoon. Suddenly, a clink, bang, crunch sound emits from under the hood for 1 to 2 seconds; then it was over. Unable to pull over to the side of the road, I kept moving while keeping an eagle-eye on the gauges. I entered our neighborhood and pulled over. I then noticed the battery gauge reading less than normal, water temp gauge reading higher than normal, and getting whiffs of ethyl glycol. Popped the hood and found a small hole in the radiator (ugh), fan belt hanging loose - not contacting the crank, either water pump or the generator pulley - because it was GONE. Luckily, it was wedged in the undercarriage. The pulley apparently, simply unscr*w*d itself from the armature. It puzzles me how it would do this as it is (I'm quite sure) a right-hand thread which should be driven tighter due to the rotation of the engine. Can anyone relate to this?? Thanks for listening to my sob story, Barney
| ford38v8 | -- 11-16-2026 @ 6:53 PM |
Barney, that’s a common failure, usually following a re-install of the generator, and more damaging in earlier models with generator mounted fans. I lost a radiator with mine, others have lost intakes, hoods, and radiators. I do have good news for you: Your comprehensive insurance will cover your new radiator as well as other damage, all except the part that caused the problem. Alan
| 40 Coupe | -- 11-17-2026 @ 5:35 AM |
The 40 Generator has a retaining ring 01A-10096-A or a clip 01A-10096-B in the recess at the end of the armature shaft to help retain the pulley. Examples of both below, since you drive your car I would suggest the clip on the left below, since I have seen the pulley removed with the ring still in place. This message was edited by 40 Coupe on 11-17-26 @ 6:31 AM
| kubes40 | -- 11-17-2026 @ 5:57 AM |
40coupe is spot on with his advice. I have witnessed numerous generators with that clip absent. I would not trust a common C clip. Rather, I would locate a proper clip. Mike "Kube" Kubarth
| Barney | -- 11-17-2026 @ 4:30 PM |
38V8, 40Coupe & Kube, Thank you so much for your input, advise and part numbers. Very much appreciated. But can someone explain to me why the generator pulley would 'unscrew' itself from the armature when the rotation of the engine is constantly attempting to screw the pulley onto the armature even tighter? Maybe I misunderstand something here, but it seems there is no need for the clip. Thanks for any 'enlightenment'. Barney
| kubes40 | -- 11-18-2026 @ 5:53 AM |
Barney, I agree that it doesn't make a lot of sense that a pulley would back off. Still, it happens. One thing to especially consider in an instance like this: Ford would NOT have cut the groove in the armature, made a clip and then install a clip if it was not necessary. Quite literally, fractions of cents were considered / counted back then when building a car. That counting (by fractions of a cent) goes on yet today. You need that clip. Mike "Kube" Kubarth
| Barney | -- 11-18-2026 @ 6:03 PM |
Hi Kubes, Thanks so much for your input. I totally agree and understand about the fractions of cents; probably even more pertinent in today's world. I wonder if the pulley spun off completely at one time, or a fraction of a turn at a time. If the latter is true, shame on me for not noticing. I would never have noticed the clip was missing; may have never had one installed while I owned the car. Appears that my first job is to purchase a 11/16"-20 tap and die set. The pulley threads look OK, but the armature threads are a bit damaged. Ya learn somethin' new every day - sometimes the hard way. Oh well. Barney
| JayChicago | -- 11-19-2026 @ 9:14 AM |
Yeah! Now I am going to check my '40's generator (and the rebuilt spare I bought) for that retaining clip. Don't want to find out the hard way.
| fordv8j | -- 11-19-2026 @ 3:23 PM |
The pully on our 38 is held on with a key, and a nut, I drilled the shaft and installed a cotter key to keep that from happening
| kubes40 | -- 11-20-2026 @ 5:45 AM |
The hex nut / key design was used through 1939. From 1940, through 1948, the pulley was threaded on to the armature, and a clip was set into a groove to keep the pulley in place. Mike "Kube" Kubarth
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18336 |
