| 1911tex | -- 11-14-2026 @ 6:44 PM |
The engine is running much too cold with no thermostat, tested at 154 degrees after a 10 mile drive OAT 62 degrees. Please I need to know if barrel type thermostats are still available or looking for a correct stock-style replacement or an easier modern workaround? I would like a 170-180 degree thermostat. Your thoughts are most welcome!
| carcrazy | -- 11-14-2026 @ 11:54 PM |
Dennis Carpenter has a 180 degree thermostat for 1937 to 1948 Fords, P.N. 11A-8575, that may be able to be made to work in you 1935.
| 1911tex | -- 11-15-2026 @ 4:50 AM |
Thank you Carcrazy..."made to work"...that is my conundrum. Sure would like to find correct size thermostats that would not require being made to work. Did 21 stud '35'36 factory delivered cars not have thermostats? I am wary of a thermostat that would flip in the hose causing more problems than no thermostat. I have heard of spot weld sleeve or attaching another hose clamp to keep the thermostat in place. What have other owners done over the years?
| marko39 | -- 11-15-2026 @ 5:09 AM |
search for nos or nors that will fit.
| kubes40 | -- 11-15-2026 @ 5:40 AM |
I'm with Marco on this one. NOS units come up on ebay with some frequency. You may also want to reach out to Mike Driskell. Fred, at Southside Obsolete may be another fellow to reach out to. Mike "Kube" Kubarth
| 1911tex | -- 11-15-2026 @ 6:57 AM |
you are correct, there are a plethora of NOS very old thermostats on ebay. Question: Reliable? Not trying to be obstinate, but risk of failure/engine damage vs. solution?
| kubes40 | -- 11-15-2026 @ 7:23 AM |
I'd just recently (month ago or so) went through my entire stash of NOS and NORS thermostats to check if they were good or not. Perhaps three dozen. Each and every one opened up at just about the correct temperature. Mike "Kube" Kubarth
| carcrazy | -- 11-15-2026 @ 8:38 AM |
Once upon a time I owned a 1969 Renault 16 which used a thermostat that fit into the cooling system hose like a 1935 Ford. One source for these Renault thermostats is Advance Auto Parts. They are available in 160 degree, 170 degree and 180 degree models. You might want to see if one of these will meet your needs.
| 1911tex | -- 11-15-2026 @ 9:07 AM |
Great info to know Mike...thank you! Carcrazy....I will follow up on your '69 Renault 16 experience....amazing what folks can remember! 1969 Renault R16 Thermostats Advance Auto Parts https://shop.advanceautoparts.com › find › 1969-renaul... We currently have just 1 Thermostat for the 1969 Renault R16 in stock: Motorad Standard Thermostat: 180 Degrees, 345-180 and it costs $11.49.
| 1911tex | -- 11-15-2026 @ 10:55 AM |
Did more research including A.I.. The upper radiator hose for a '35/'36 21 stud engine has a 1-3/4"I.D., which is 44.50mm. The closest I found is Yanmar 160 degree (71 degree celsius) 44.50mm flange, a good tight fit. Wish it was a 170 or 180 degree; however, better than nothing. They are available at tractor supply stores at much higher cost: https://www.ebay.com/itm/365284717537?chn=ps&norover=1&mkevt=1&mkrid=711-166974-028196-7&mkcid=2&mkscid=101&itemid=365284717537&targetid=2304343365564&device=c&mktype=pla&googleloc=9197326&poi=&campaignid=23654106120&mkgroupid=193023571094&rlsatarget=pla-2304343365564&abcId=10643803&merchantid=5519540888&geoid=9197326&gad_source=1&gad_campaignid=23654106120&gbraid=0AAAAAD_QDh-jvxgtXESfi1t6PN-NrYzf0&gclid=Cj0KCQiAzeXXBhCGARIsADO5-zGV88uXTL9YOtfyT56fn6yU38eHREK27je60xdZPZUSy8ezx9qhRPcaArE8EALw_wcB Question: where should the thermostat be placed in the upper hose...at engine or at radiator? Facing which direction...? Thanks! This message was edited by 1911tex on 11-15-26 @ 6:37 PM
| ford38v8 | -- 11-15-2026 @ 2:24 PM |
At radiator will give a higher temp before opening. Should have a 1/8” hole for continuous flow regardless. Bimetal sensor faces heat source. Alan This message was edited by ford38v8 on 11-15-26 @ 2:25 PM
| 1911tex | -- 11-15-2026 @ 6:20 PM |
Thank you ford38v8!
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18333 |
