Topic: AC 9597 Fuel Pump
wlobb    -- 11-07-2026 @ 7:39 AM
  Hi you guys, its been awhile. Last winter I tried to rebuild my fuel pump. Best I can tell it an AC 9597 fuel/vaccum pump. I was able to replace the fuel side with a diaphram from another kit, but the rubber oil rings were in bad shape and I never got them replaced. it ran great all summer but now I have a leak between the fuel and the air side.
I have looked everywhere for a rebuild kit for this pump, there seem none to be found. All I really need are the rubber oil rings. To be honest I don't ever drive my Shoebox in the rain so the wipers and vacuum side don't matter all that much. I have a '51 8BA.
I am thinking of hooking up the vaccum line to the wiper right off the intake below he Model 94 carb and just using a regular fuel pump. They seem to be readily available. Like I said the wipers dont matter much and even with this truck fuel pump they are not too fast.
Does anyone know where I can find a rebuild kit for the AC 9597 or who has/makes a good replacement fuel pump only. I have a 6 volt electric pump I use from a primer when I need it, but my focus with this car is to keep it and drive it as close to factory as it was in 1951.
Thanks, Bill
This message was edited by wlobb on 11-7-26 @ 7:41 AM
Kens 36    -- 11-07-2026 @ 8:05 AM
  In my experience, I have found the best fuel pump rebuild kits, including kits for dual-action pumps, from Then and Now Automotive in Massachusetts.
https://www.thenandnowautomotive.com/#CONTACT
Ken
wlobb    -- 11-07-2026 @ 10:57 AM
  Thank you! I’ll check them out!
marko39    -- 11-08-2026 @ 4:54 AM
  try daytona parts they have good kits for almost everything.
Kens 36    -- 11-08-2026 @ 7:59 AM
  Are you sure about that? I have never known them to have fuel pump kits. They DO have the best carburetor kits.
Ken
carcrazy    -- 11-08-2026 @ 11:47 PM
  You can just use a conventional simple fuel pump without the vacuum pump feature and still get the wipers to function while the car is accelerating.
You can use a "vacuum can" along with a one-way check valve. You will want to connect this can to the manifold vacuum tube on your intake manifold. To plumb it up correctly, you will need a length of vacuum hose into which you first insert the check valve, then a tee fitting and finally the vacuum can. Connect another hose from the tee fitting to you windshield wiper motor. This will allow vacuum from the intake manifold to be trapped in the can to be used when you turn on your wipers and used when the engine vacuum is less than required for proper wiper function.
marko39    -- 11-09-2026 @ 4:54 AM
  ken is correct, carb kits
wlobb    -- 11-09-2026 @ 4:25 PM
  Funny story, yesterday I ran the vacuum line right to the manifold and plugged the in and out the bottom of the pump and they worked just as good. I like your idea in here. I’m going to do that! Thank you
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18329
