Topic: carburetor problem
silverchief    -- 11-06-2026 @ 9:22 AM
  Just received carburetor back from a reputable rebuilding shop for my stock 49 nFord flathead V8
Car starts easy and idles smooth at 500 rpm. However even moderate acceleration is rough with soft backfiring.
and sudden fast acceleration is met with a moments hesitation before response,
Have tried adjusting fuel/air mixture screws with no improvement.
Appreciate any suggestions
pauls39coupe    -- 11-06-2026 @ 10:04 AM
  Call the rebuilder for their opinion. It sounds like a problem with the accelerator pump, or the power valve. Try looking down the carb with the engine shut off open the throttle and look for a stream of gasoline shooting down the center.
Have you tried changing the pump linkage? It is the cam like device at the bottom of the linkage marked 1.2.3.
The mixture screws will not have any affect on your problem.
Paul R
This message was edited by pauls39coupe on 11-6-26 @ 10:06 AM
carcrazy    -- 11-06-2026 @ 12:18 PM
  It sounds like your accelerator pump is not squirting the required amount of fuel into the throttle bores during acceleration. Causes for this could be blockages in the accelerator pump discharge jets, pump ball check missing, accelerator pump piston missing or severely damaged or accelerator pump linkage disconnected.
Kens 36    -- 11-06-2026 @ 1:42 PM
  Have you verified that your vacuum advance is working?
Model B    -- 11-07-2026 @ 5:11 AM
  I'm with Ken36 on this one. What did the carb (engine) act like before you had the carb rebuilt? I had a similar problem and I replaced the vacuum advance can and it ran great.
Good luck,
Pat
carcrazy    -- 11-07-2026 @ 8:31 AM
  The problem could be that the vacuum line between the carburetor and the distributor hasn't been connected or has a severe leak.
silverchief    -- 11-07-2026 @ 9:53 AM
  Thanks very much guys.
Regarding vac line, during recent shop work techs saw vac line connect at carb had threads stripped, so they capped it off and moved the line
direct to manifold under the carb.
Also looking down throat of carb while pulling accelerator rod shows gasoline coming from jets but certainly not a strong stream.
I will talk to shop.
Thanks again.
Kens 36    -- 11-07-2026 @ 11:18 AM
  The vacuum line must connect to the correct port on the carburetor or it will not work. This is likely your problem.
Ken
silverchief    -- 11-08-2026 @ 2:46 PM
  As an update guys I have made progress with my carburetor except I still have moderate back firing at a fast idle or routine operation.
Never a loud bang but easy for the driver to hear.
I know there is an almost always reason behind back firing but have long ago forgotten it.
Please point me in the right direction.
pauls39coupe    -- 11-08-2026 @ 5:59 PM
  What have you done so far to correct the problem? I agree with the others that your troubles may be related to vacuum advance.
Make sure the distributor points are set correctly, disconnect and plug the vacuum line, then using a timing light properly set the timing. Reconnect the line to see if the vacuum advance is working.
The Load-o-matic distributor should be connected to the carb as it operates correctly on ported vacuum, not manifold vacuum.
carcrazy    -- 11-08-2026 @ 11:31 PM
  Your distributor is of the Loadamatic type which is totally dependent upon the vacuum signal provided by the carburetor port to achieve the correct spark advance. The port on you carburetor provides a vacuum signal which is a combination of carburetor throat and venturi vacuums.
There are several things that may be causing the engine to backfire into the intake manifold:
1. Lean mixture
2. Engine cold and choke mixture is too lean
3. Leaky or sticking intake valve or broken intake valve spring
4. Leakage of electrical current across distributor cap
5. Two mixed up spark plug wires
These last two items may be causing the spark to occur too early when a cylinder is on its intake stroke.
silverchief    -- 11-09-2026 @ 3:34 PM
  Thanks very much Carcrazy - very helpful information re carb and distributor set up
that I was not aware of. I had only a general idea but did not realize how critical their interaction was to good performance.
Now I am going to pull the carb and reroute the vac line as it was originally.
Thanks again.
silverchief    -- 11-11-2026 @ 2:46 PM
  Thanks Paul,
I repaired the vac line connection into the carb and ran a new line there as you suggested. Several members pointed to the vac line
as the likely culprit so I was really hopeful things would change
Not to be. Same rough running with constant moderate back firing whenever the engine is running, Tomorrow I will be sure there is vac
coming from the carb to the vac unit itself, and if there is I will find out how to test it.
carcrazy    -- 11-11-2026 @ 3:12 PM
  Connect a vacuum gauge to the vacuum port on your intake manifold that goes to the windshield wiper motor. Measure your intake manifold vacuum at idle speed. At sealevel the reading should be about 19" of mercury. Your vacuum reading should be steady. If your location is above sealevel, it should be about 1" less for each 2000 feet your location is above sealevel.
TomO    -- 11-12-2026 @ 1:36 PM
  Please post a phot of the carb and the vacuum line going to the distributor.
pauls39coupe    -- 11-12-2026 @ 4:59 PM
  Silverchief, have you contacted the rebuilder or tried a different carburetor?
Paul
silverchief    -- 11-14-2026 @ 2:56 PM
  Tom -will post photo
Paul - without my permission, shop took off my original Holley carb, replaced it with cheapo Japan carb, and rerouted vac line from the carburetor
to just under the carb.
My car ran great, until I took the Japan carb off, off, had my original rebuilt at a reputable shop, put it back on, and ran the vac line back into my carb
I'ts been a nightmare since. Won't start without full choke, and stutters and backfires from fast idle to moderate speed.
Over the years I have gone to a lot of trouble to keep my car original that's not going to change. I still appreciate your input.
carcrazy    -- 11-14-2026 @ 3:09 PM
  You may have a major vacuum leak somewhere. Check your manifold vacuum with a gauge connected to the tube which connects the intake manifold to your vacuum windshield wiper motor. The reading should be about 19" at sealevel.
Check to make sure your carburetor is tightly mounted to your intake manifold. The nuts which secure it to the manifold should be torqued evenly to about 10 ft. lb. with a new gasket.
pauls39coupe    -- 11-15-2026 @ 3:13 PM
  Car Crazy may be on to something related to vacuum. I wonder how they hooked up the vacuum line. Did they drill and tap the manifold?
Off chance they hit the exhaust crossover. Photos would help us.
New carbs made in the USA by Dennis Carpenter and others have worked well for us, but may be lacking the original part numbers for fine point judging. Great for drivers.
Kens 36    -- 11-19-2026 @ 7:34 AM
  My post 12 days ago still applies. "The vacuum line must connect to the correct port on the carburetor or it will not work. This is likely your problem."
Ken
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18328
