| HaroldL | -- 11-05-2026 @ 5:41 AM |
Looking for a recommendation for an electronic ignition on my original engine. Petronix wants to know the number on the side of the distributor. I am not able to find this. Your help would be appreciated. Harold Legreid
| 51504bat | -- 11-05-2026 @ 6:26 AM |
Year, helmet, crab, Lodomatic? That said get ready for the posts about you don't need no stink'n electronic distributor -points work just find and you can fix them on the road. ______________ No signature
| nelsb01 | -- 11-05-2026 @ 7:34 AM |
I'll start. Be prepared to also purchase extra items to make Petronix work. Their coil also. I tried it. Fried it. Towed it home. Sent it back. They sent new. Fried that one also. Went back to tried-and-true points and condenser. Sold my second replacement at a swap meet. But it does work for others. This is just my story.
| carcrazy | -- 11-05-2026 @ 9:22 AM |
The best ignition system for your original Ford is the dual point one that came on it from the factory. Once this distributor with points is setup properly on a distributor machine by a competent technician, it is essentially bullet proof for 15k+ miles. If you want to drive the car on extremely long trips, it is good to carry a spare original fully set up distributor with you in the car. This message was edited by carcrazy on 11-5-26 @ 9:25 AM
| JayChicago | -- 11-05-2026 @ 9:58 AM |
No direct knowledge, but my understanding is that the electronic ignition modules are very sensitive to voltage spikes. Original generators do not operate in tight voltage parameters like a modern alternator and thus produce the problem as related above by Nels01. But I have read that some have had no problem with electronic ignition; not sure how their cars are different.
| pauls39coupe | -- 11-05-2026 @ 2:19 PM |
Change all the plug wires and the coil wire to a carbon type non metalic wires. The original wiring will not play nice with the electronic ignition.
| HaroldL | -- 11-05-2026 @ 3:08 PM |
I appreciate all of the advice, looks like I will stay with the points etc. Thanks. Harold Legreid
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18327 |
