Topic: Engine year
flathead48    -- 10-20-2026 @ 9:56 AM
  Would this be a 37 engine ??
Thanks, Rick
carcrazy    -- 10-20-2026 @ 1:03 PM
  No, this is not a 1937 Ford engine. This is an earlier engine.
flathead48    -- 10-20-2026 @ 1:07 PM
  Carcrazy, do u know what year ?
carcrazy    -- 10-20-2026 @ 1:25 PM
  I do not know. It could have a later replacement (1937) engine block with the provision for using the block-mounted water pumps. The cylinder heads and distributor/coil on this engine are from an engine built prior to 1937.
TomO    -- 10-20-2026 @ 5:50 PM
  It looks like a 37 engine with earlier heads and block off plates used to install the later block in an earlier car. I am not sure, so I would ask the 1937 Ford Advisor listed in the V-8 Times.
I have attached some pages that I scanned in 2013. I think they are from a V-8 Times article. They can be used as a rough guide to the engine blocks used by Ford.
flathead48    -- 10-22-2026 @ 2:15 AM
  Thanks to all for the input. THE BEAUTY of flatheads u can put an engine together using parts from different years & end up with a really nice running engine .
v8fordman    -- 10-31-2026 @ 7:30 PM
  It’s definitely either a ‘37 or early ‘38 with block off plates. The heads appear to be cast iron replacements with block mounted water pumps. The distributor is a ‘33-early ‘36, but it doesn’t matter to the engine.
flathead48    -- 11-01-2026 @ 2:41 AM
  Thanks V8 fordman, appreciate the input. Rck
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18305
