| jamesmundstock | -- 09-02-2026 @ 1:39 PM |
I have new springs on my hood hinges and the hood barely stays up. A slight breeze will code it. I had an old timer with a show car at Hershey tell me to cut the spring hook flange off and weld it 1/4” further to put more preload on the spring. Has anyone tried this remedy. I do not want the gas strut fix. I want it to look original. Thanks in advance for the replies.
| woodiewagon46 | -- 09-03-2026 @ 6:38 AM |
James, read my post from last week. Those springs are under a lot of tension especially when the hood is closed, so I wouldn't do any welding on them. The spring that broke on my '46 went flying down, thank goodness and didn't do any damage. I purchased a replacement spring from Dennis Carpenter and It worked fine. If I were you I would purchase two springs from Carpenter and do the job the right way. I fabricated a spring spreader to install the new spring and needed to stretch the new spring over 4 more inches to get it on. A drop of oil on the hood pivot points might help. Be careful!
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18249 |
