| jamesmundstock | -- 08-24-2026 @ 9:45 AM |
The 46 to 48 hoods are three pieces. The left and right halves and the center raised rib. There is a slight gap between the raised rib edges and the left and right half tops. In places the primer fills the gap but most is still open. I am concerned when I paint the color, you will see gap closures and gap opens. I know the gap was open from the factory. Would you restorers apply a thin bead of seam sealer in this gap so it looks consistent? Thanks in advance for the reply.
| kubes40 | -- 08-24-2026 @ 10:01 AM |
Allowing primer and / or any paint to "fill the gap" is a rookie mistake. A little drying, a little flexing and that "filler" is going to crack. Same sealer is probably your best option. My best option would be to NOT fill the gap. Mike "Kube" Kubarth
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18237 |
