Topic: 1953 ford sunliner convertible brake light switch
1953fords    -- 07-30-2026 @ 3:19 AM
  My brake lights run off of a 6volt system stay on very dimmly. pulled brake light switch wire off and they went off. Will just replacing the switch fix problem or a new master cyclinder fix it. I read that sometimes in an old master cyclinder the rod sticks inside and may cause the brake lights too stay on. Anybody ever have this problem???
carcrazy    -- 07-30-2026 @ 9:16 AM
  Most likely just replacing the switch will cure the problem. Do you have sufficient brake pedal free travel? It should be between 1/4 to 7/16 inch.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18198
