Topic: Bolts for 1936 engine/trans
PapasV8    -- 07-21-2026 @ 5:48 PM
  I am preparing to install the rebuilt engine and transmission onto the body-off frame of my 1936 5-window coupe. The transmission was removed 30 years ago by someone else and I am missing bolts. Could someone provide a detailed description of the 2 bolts required to mount the Rear Engine Support Assembly to the frame and the 10 bolts needed to mount the transmission to the engine/clutch assembly? I have not been able to find this information in the 1935-35 Ford Book, although there is a photo that shows the heads of the former on pg 82.
nelsb01    -- 07-21-2026 @ 9:28 PM
  Here you go.
You need to contact Third Gen Automotive -- Hardware Kits
https://thirdgenauto.com/wp-content/uploads/2021/08/MARCHv8CATFOR-WEB-USE-2018.pdf
page 16
PapasV8    -- 07-21-2026 @ 9:57 PM
  Thanks, it looks like there is a lot of great stuff there.
nelsb01    -- 07-22-2026 @ 6:03 AM
  Yes, there is.
As you can see, the original hobby business was started by Roy Nacewicz, a very knowledgeable person with regards to restoring Early Ford V-8s.
The good news is that the business is being continued by another very knowledgeable person in the hobby. Third Gen Automotive can help you with your needs and questions.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18184
