Topic: Light switch
Salzer    -- 03-24-2026 @ 10:19 AM
  36 Coupe. Does anyone have a suggestion how to remove the rod to the light switch other than dropping the steering box and steering column. When I pull the rod out I hit the brake off f
kubes40    -- 03-24-2026 @ 10:39 AM
  You will need to drop the column a little. Disconnect at the instrument panel and remove two of the three bolts that hold the box to the frame as well as the pitman arm.
You can then pivot the column enough to remove the horn rod out through the rear windshield (rolled down of course).
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=18047
