Topic: How to install spring clips in U joint, early ford
moxie1945    -- 08-29-2025 @ 7:17 PM
  Kit contains a new cross, bushings and springs but no instructions. I have the joint apart but can not figure out how to install the spring clips. On line it stated to be careful that clips could pop away when installing but it does not tell how to install clips. I have joint apart with bearing sleeves and spring clips. Need a little help
trjford8    -- 08-30-2025 @ 9:29 AM
  I believe you need a special pair of pliers to install them. Take the clip to an automotive parts store and they may have the pliers you need.
40 Coupe    -- 08-31-2025 @ 4:27 AM
  delete
This message was edited by 40 Coupe on 8-31-25 @ 4:28 AM
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17735
