Topic: 1939 Deluxe Headlights ???
Statewurker    -- 07-21-2025 @ 5:36 PM
  Everything moves freely , pulled switch at the bottom of the gear box and moves freely into its positions. How do you split it apart to look at the wiring? The horn works sometimes also. Turn signals and hazard lights all work. Glass fuse way up under the dash looks good also. Have I missed something ? Also it seems this switch has 4 position but I have the high / low beam button on the floor. No dash lights or interior lights either.
1939 Ford Deluxe, all original , 85 hp , new to me 7/2025.
NEWBY!!!
ford38v8    -- 07-21-2025 @ 6:34 PM
  Turn signals and hazard lights are aftermarket, not part of that system anyway. Interior, dash, and exterior lights are all fed from the fuse under the dash that "looks good." Remove that fuse and replace from an auto supply exact size and shape.
Statewurker    -- 07-28-2025 @ 10:24 AM
  Been busy with life and hadn't been back in the shop to look at the old girl. I will look tonight and update. Thank you.
NEWBY!!!
Statewurker    -- 08-03-2025 @ 9:18 AM
  Tested fuse , it’s good. Was able to get the interior lights to work but no luck with take lights or Head lights.
Bad thing happened when checking bulbs in rear, I dropped a lense ( slipped out of my hand) and shattered it on the floor. Now I have to find a new one.
NEWBY!!!
This message was edited by Statewurker on 8-3-25 @ 9:27 AM
carcrazy    -- 08-03-2025 @ 9:53 AM
  C&G has the tail light lens you need in stock.
https://cgfordparts.com/tail-light-lens-38-39-passenger-ex-wagon-glass-81a-13450.html
40cpe    -- 08-03-2025 @ 11:43 AM
  keep in mind that there are several different shades of red that can show up in the lense in case you want to order a pair.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17690
