| 41fatty | -- 07-14-2025 @ 1:57 PM |
if I change my ring and pinion from 3.78 to 3.54 will i need to change my spider gears ( 11 tooth) and/or my axles( 16tooth)? will they mesh? they appear to be in fine condition, other than the usual seals bearings races etc.
| juergen | -- 07-16-2025 @ 5:26 AM |
The ring and pinion are compatible for the same eras like 1937-48. Of course you will need a lower teeth turtle.
| 41fatty | -- 07-16-2025 @ 11:39 AM |
what's the difference between turtles and spiders? I am not sure that I need to change the 4differental pinions that attach to the spider.
| MG | -- 07-16-2025 @ 11:57 AM |
"turtle" - Reference to the speedometer gear which you will have to change if the ratio of the rear end is changed... A pinion with 11 teeth and a ring with 39 teeth will give you a rear with a 3.54 to 1 ratio... This message was edited by MG on 7-19-25 @ 9:53 AM
| 41fatty | -- 07-16-2025 @ 4:34 PM |
thank you, duly noted, but; what if ( and when) i run on 16 in. wheels, will there be much of a difference? keep in mind I was always happy running on 3.78 configuration and am still looking for the same 9-34 ring and pinion but at what cost?
| 41fatty | -- 07-16-2025 @ 6:30 PM |
correction, I meant 15in. wheels, opposed to 16
| JayChicago | -- 07-17-2025 @ 10:16 AM |
If I'm not missing something, here is an approximation: 16 " wheel plus 6 " tire = 28 " diameter X 3.14 = +/- 88 " circumference, travels 88" with each tire revolution. 15" wheel plus 6" tire = 27" diameter X 3.14 = =/- 85" circumference. Travel per revolution is 3.5% less. Your existing 3.78 gear ratio, plus 3.5% more engine/drive shaft turns per travel distance = 3.91 Going to 15 " wheels is equivalent to changing gear ratio to 3.91
| JayChicago | -- 07-18-2025 @ 7:51 AM |
Whatever differential gear ratio you have, a change to 15" wheels will give the same 3.5% more engine turns per distance of travel. With a 3.54 gear, going to 15" wheels is equivalent to a 3.66 gear.
| juergen | -- 07-19-2025 @ 6:13 AM |
And switching to a 3.54 from a 3.78 will give you a 6.3% lower engine speed (or reading in mph). Together with the 3.5% in the opposite direction will result in a 2.8% change in speedometer reading. At 60 mph this is in the ballpark of speedo error.
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17674 |
