Topic: 1936 Oil Pan vs 1935 Oil Pan
BIRUDY    -- 07-12-2025 @ 8:50 AM
  What differences are there, if any, between a 1936 21 Stud LB block oil pan vs 1935 21 stud oil pan?
I understand the 1936 LB block has insert bearings on the mains and the main caps are larger than the 1935 engine.
Thanks Rudy
gmcbuffalo    -- 07-28-2025 @ 3:45 PM
  Rudy I think they are the same. Since I have a 1935 pan on a 1937 engine
Greg Meiling
1935 3 Window Coupe
v8er    -- 07-29-2025 @ 2:49 AM
  The 1935 oil pan has an offset drain above the wishbone. The 1936 oil pan has a center drain.
40 Coupe    -- 07-29-2025 @ 5:38 AM
  There is an early 35 pan with the 34 style of dip stick tube and cast bracket. The club restoration book covers differences.
pauls39coupe    -- 07-29-2025 @ 7:27 PM
  The 36 LB pan is deeper around the front main cap. Ford's solution to fit an early pan on a LB engine was heavy use of a ballpine hammer.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17666
