| JohnA | -- 04-30-2025 @ 10:40 AM |
on my 48 2dr sedan, I.am ready to install front fender and webbing between cowl and fender, is it best to fit webbing on fender first and then install or is there a better way.
| fordv8j | -- 04-30-2025 @ 3:41 PM |
Yes it is better to fit it to the fender first-- a thin double sided tape can hold it in place
| nelsb01 | -- 04-30-2025 @ 4:21 PM |
Or..............rubber cement (available at office stores) Using rubber cement you have the ability to re-set the webbing if it is not in the correct place. Two sided tape sometimes is not as forgiving.
| JohnA | -- 04-30-2025 @ 6:27 PM |
Thanks, again Johna
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17570 |
