Topic: 12 V conversion-Sparks!
hotroddoc    -- 04-26-2025 @ 11:07 AM
  Hello,
I just converted my 36 from a 6V positive ground to a 12 V Negative ground. I kept the floor starter button. New dash and body harnesses were replaced. Lights and horn are working correctly.
When I depress the starter button, Sparks fly around the starter button. Do I need to change something with the starter since the system was positive ground? Should I switch to 12volt Positive ground?
Thanking you in advance.
Gary
This message was edited by hotroddoc on 4-27-25 @ 5:38 AM
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17566
