| square nutz | -- 04-12-2025 @ 7:51 AM |
where is the serial number/vin located on 1936 ford sedan thanks
| ford38v8 | -- 04-12-2025 @ 9:36 AM |
Top of driver side frame rail in the engine compartment. Likely covered in grease, so just clean it off to read it. Don’t use abrasives, as the number was hand stamped and may be destroyed if you get too aggressive in cleaning it. Alan
| CharlieStephens | -- 04-12-2025 @ 7:07 PM |
See: http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm Charlie Stephens
| square nutz | -- 04-13-2025 @ 5:39 AM |
very good. Thank you
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17530 |
