Topic: 1935 ford
39FORDPU    -- 03-24-2025 @ 8:38 AM
  Can anyone tell me where the serial number is for a 1935 ford is. Thank you
mikecnc    -- 03-24-2025 @ 8:45 AM
  On the top surface of the frame between the cross member and steering box. Also on the frame in 2 places on the left (drivers side), but covered by the body. You will have to remove the paint and rust/corrosion from the frame surface to find it; it is stamped into the metal.
39FORDPU    -- 03-24-2025 @ 11:04 AM
  Thank you, I found it.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17506
