| chucky | -- 03-10-2025 @ 6:59 PM |
Does anyone have any experience with Hot Rod Works parts. Thanks...
| FordFreak | -- 03-12-2025 @ 7:16 PM |
I have no experience w/them, but if you are in need of stock rear end parts you can't go wrong w/ Mac VanPelt. He sells good, quality parts along w/great advice. His prices are reasonable, also. He is highly recommended on here & other old Ford sites.
| trjford8 | -- 03-13-2025 @ 8:39 AM |
Hot Rod Works does conversion type work on old Ford rear ends. They make conversions to open drive line and put later axles in the rear ends. They do have a good reputation if you are looking to update the rear end. If you are doing a strictly stock rear end I would try Mac Van Pelt,
| carcrazy | -- 03-13-2025 @ 2:59 PM |
If you want to use a later Ford rear end like an 8" or a 9" model, Currie can probably supply any parts you will need. They can also modify the later axle to properly fit under your early Ford. https://www.currieenterprises.com/?srsltid=AfmBOor85IWRK873x4O0iOhWpuWZ_SyEhqb4rq_BzPSeL8QhgRbeDnzV
| chucky | -- 03-13-2025 @ 5:35 PM |
Thanks guys, I appreciate the help
| Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17487 |
